On and Off . . .while in the water
We use On and Off while the boat is in the water as it works extremely well without a lot of rubbing, and when it is in the water, the bottom paint is not affected. We use a disposable type of mop for this operation and do it from the dock.It also allows for ample rinsing. Only problem is the aft end . . . which we carefully address after the boat is hauled for winter storage . . . and again using ample rinsing.BTW, rubber gloves for the aft end helps keep the pinkies in proper condition.
