Running for Cover
If inland or coastal and within range of safe harbor, I'd definitely try to get there. Any protection from the strong gusts associated with a front is a great help in keeping crew safe. Once at the harbor, the rule is generally to secure all but essential equipment; that means actually disconnecting it from the boat. My rig has a hinged connector plate. All of the boat's electronic equipment has power, cable, and antenna connections/connectors mounted to a two shelf hinged system. (One for power, the other for antennas, etc.) When electrical storm is near, I turn all equipment off and disconnect the connector system. Naturally, all of the above depends greatly on the amount of time one has to "run".If safe harbor is not available or timely, knowing the direction or path of the storm is very helpful. I could alter course, reduce sail, and possibly direct the vessel to the "weakest" possible point of the storm. When course is changed all crew prepare by disconnecting electronics, etc., setting up for gust and/or knockdown (secure all hatches, install companion boards, secure missile hazards, etc.), getting safety harnesses and gear ready if not already (heaving lines, tethers, jacklines, Type IVs, etc.), and don't touch anything metal. (This is one reason I am a firm disbeliever in metal hand rails on a crusier. I'd install a teak wheel, too, if I thought it would perform as well as the Destroyer.) The helmsman gets to wear the electrician's gloves and hold the wheel with thick innertube rubber.
