Comfort or heavy performance?
Hi Ray,I own a h26 '96. I've had two of them so I guess it could be said that I like the boat. The hull of the 26 and the 260 are the same so many of the characteristics are the identical. I'm sure that others will be able to tell you about the changes that were made to the rig and the characteristics that result. I'll tell you about the facilities, on the boat, that we enjoy.At 5'8'' (I'm a shrimp) I can stand straigt up without opening and raising the companionway hatch. The head being enclosed is a big plus for the lady in my life and the kids. It's a tight fit to get anything done in the head but it's the best I've experienced in a boat this size (5 gal. portapotie holding tank is desirable). The galley, sink, cooler/counter space is minimum, but it is a deticated space that is adequate with a system employed. Water capacity can be increased to 10 gallons with larger bladders and I recomend it (5 gal. in't enough and the disposition of the increased ballast is desirable). The salon table and seating is spacious and very comfortable (upgrade cushion fabric is a must!). Storage for food, pots/pan & equipment requires some thought and prioritization, but the space is ample, for a 1-2 week cruise. Berthing astern is spacious but the overhead is constanly there, and my woman insists on being the last one in because of the clostraphobic sensation she gets in the back. My, full size, son likes the Vbirth up front and has slept there with a companion. The cockpit is the largest I've seen on boats well over 30 ft, and we love it (we have tiller stearing). The deck is stable to walk around on and is easy and spacious. Anchoring the H26 has been very secure since I employed the use of a 16 pound Kellet dropped to the chain (15ft of 5/16th) and a 16 lb. 18" Danforth. The 9.9 Tohatsu has given us lot's of power (9 gal. fuel tank good capacity) and w/flexable solar panel to recharge only minimal consideration has to be given to electrical consumption (lights, GPS, VHF & Autopilot are used consistently and the stereo used ocasionally.Water Ballast / Swing Keel has given us tremendous freedom to explore and experience a lot of diverse waterways (open sea isn't my passion). Not being a displacement boat it rides quietly over the water without large bow wave or wake. I'ts fast and very responsive. It tends to round up in heavy gusts but with vigilance and a willingness to size and shape the sails (moderate heavy) weather is manageable and confidence levels are high amongst my entire crew. I don't expect the H26 or the 260 to perform like a heavy displacement cruiser and I rather enjoy the satisfaction of being able to control the boat with control input when it's necessary. We are able to use the autopilot nearly all the time and truely enjoy the flexibility of our trailerable cruseing yatch. We get an enormous amount of pleasure and utility from this investment.I hope that this information helps you to determine whether the 26 ft Hunter meet with your needs and expectations.All the best!Larry Barnes, vessel "CNTRL SEA"
