Dear Glenn,
thanks for offering your highly appreciated advice on this forum.
Mostly everyone ends up doing modifications or adding gear to more adapt their boats to their tastes\needs.
Here I was thinking(fantasizing) about possible modifications that DIRECTLY effect the behaviour of the boat. Well, the intention is to improve not ruin it.
My question is, to what extent one is allowed to mess about the standard configuration of a boat without causing harm?
Although this is a general open question, our boat is a Hunter 23.5 water ballast. Examples of things that go through my mind ;
Replacing the fixed jib-sheet blocks with adjustable car.
Adding another reef to the main, near the boom (intention is to flatten in a blow since it is designed with a big belly)
Constructing a skeg\stump in front of the centreboard and possibly going aft around opening(intention is to improve directional stability upwind in very short choppy waves)
Inventing some different uphaul for the (heavy) rudder blade
or something else that you suggest.
Thanks for bearing with me.
