My 89 Cat 30 has been running hot. I have owned the boat for 9 years and it usually runs between 160 and 170 degrees. I have maintained my 3" heat exchanger by having it boiled out every two to three years. I replace my zincs every Spring. I also change my impeller every other year along with my hoses. I see plenty of water exiting the exhaust. I recently purchased an IR Thermometer and believe my temp gauge is reading correctly. I idle perfectly at 160-170, but rise up to 180 while under way. I just cleaned my raw water strainer and flushed the raw water through hull. I also replaced my thermostat (160 F). What can I check next? I realize the engine can run up to 180, but I am in salt water and have always run much cooler. Something is not right and I have no idea what it could be. Normally, when I run at 160 you can feel cool to warm exhaust water exiting. When it hits 170 you see some light white smoke and the exhaust water is hot to the touch.
