Last weekend I noticed that my alternator is running quite hot, surface temp definitely exceeded 100°C (212°F). I noticed a smell like burnt rubber, which alerted me to check on the engine. I just bought the boat this spring so I have little experience what is normal and what is not. I did not notice this problem in 2 or 3 few short trips I made since the purchase. I think the smell came from some (not excessive) amount of rubber dust from the v-belt that landed on the alternator. The rest of the engine seemed normally hot, the cooling water was running fine all the time.
Is such high temperature still in acceptable range? What is acceptable maximum?
Details: I have a Hunter 33 (2006) with Yanmar 29hp. Alternator is 60A. I have 3 batteries in 2 banks (1 starter and 2 in house). They are all the same deep cycle maintenance free, do not know exact Ah but by the looks they are probably about 110 Ah each.
During this last weekend's trip I have discharged the batteries a bit (good wind, little motoring) and among other things I used the windlass several times in 50Ft anchorage (dropping and hauling 100 ft of chain plus some line).
Would low charge of the batteries force the alternator to work extremely hard? I thought the alternator would have a current regulator that would prevent overcurrent. Is there any changeable setting on the regulator?
Any help will be appreciated,
Tomek
Tomek
