C
Claude L. Auger
As I pulled out of my slip yesterday, I notice some white smoke coming out of my exhaust. I did have plenty of water coming out of the exhaust. Running the engine to 3000 (max RPM for my 20 HP is 3400)quickly brought an overheating situation and there was plenty of steam in the engine room as well as a hissing sound as if water was thrown on hot metal. I shut the engine down and we sailed all day. Before coming back in, I refilled the system with the proper mixture of antifreeze and water, as well as the overfill tank, which had also been drained, and started the engine only when I was about to pull into the slip.I went back today to investigate.1) Lake water is already too cold to jump in (we haul out on 10/15 for the winter) but I had lots of water coming in through the through-hull.2) Impeller checked out OK. No signs of wear and no visible-cracks.3) Thermostat opens and shuts properly when checked in boiling water. It is marked for 71 degrees, and it did open before water boiled (100 degrees C).4) All antifreeze had found it's way in the bilge, yet none of the hoses were leaking.5) Even with the engine not running, whatever coolant I add through the rad cap vanishes rapidly. I did not let the engine run long enough today to avoid overheating it.Has anybody ever had this problem, and if so, what might be the solution. Thanks in advance.
