The water cooling system on my dinghy's quite new 9 horse Yamaha 2 stroke outboard failed and, not at first noticing the problem, I continued to operate the engine...... which I assume then overheated. This winter I will of course fix the cooling. However thinking back on the experience, I realized that the hot and cold starting on this twin cylinder motor (whch had always been amazingly good) suddenly dramatically deteriorated after the overheating problem.
What are the usual consequences of overheating these motors? With the sudden onset of hard starting, I suspect the best case scenario might be a blown head gasket. :cussing:
Also a word of warning to anyone using a Davis outboard lifting harness. Don't let the harness strap cover the water cooling discharge port!!!!
