John
The forward (electric)head on my 1991 Hunter 42 was filling up and overflowing after flushing. THis started suddenly with no other symptoms that I am aware of in the two weeks that I've had the boat. The seacock was frozen in the open position so I removed the seawater intake hose between the PAR pump and the top of the bowl and plugged it. Fixed the problem, and subsequently I replaced the entire pump mechanism. Works fine now but I'm perplexed as to why the head overflowed... there apparently is a vented loop in the seawater intake line, since when I was replacing the pump, removing the intake hose produced no water flow. I guess that there is some kind of a siphoning effect taking place? Any ideas as to why and how to fix? Could it be that the vent to the holding tank is clogged (I'm away from the boat this week and didn't think to check that possibility) and it was drawing water through the loop and into the head? Running the macerator did drain the water in the head when it was filling up...... or could it be that there is pressure in the holding tank that was forcing water back into the head and overflowing? Help!
