H
Hugh
I'm not sure whether I have a problem. When I'm charging the batteries off the alternator, the voltage read at either of the batteries seems to go too high. Running my Vetus 20HP at just under hull speed, ( I don't have a tach), the voltage read across either battery quickly rises to over 16 volts ( at which time I cut off the field disconnect). I can charge better with the engine idling, or at slower speeds, but the voltage still rises eventually. Is this indicative of a bad regulator? I have a dual output alternator feeding both batteries directly.
