Dale I
After a week or so of inactivity my house batteries (two T-105's, less than 6-mo old), had 12.74 volts, and the cranking battery, (marine battery, 2+ years old), had 12.74 volts remaining. After cranking up the little yanmar, (2QM20H), I let it warm up at idle for 20 minutes and as usual the alternator was almost too hot to leave my hand on.... Upon checking the volts the house and cranking had 13.34 and 12.92 volts, respectively. The unit came with a high-output alternator, (90-amps output on a bench last year) and has a small diode installed on the brown wire, (sensor wire?). Is it possible that the thing is stuck on 'full on' and doesn't know enough to shut off? It has an internal regulator. What is the diode for? What can make a regulator go bad?....help. Will be taking it to a shop for another check-up, I guess....but it'd be nice to know what to expect the prognosis to be. (nothing found in the archives regarding 'overcharging'.) Hydrometer readings were generally consistant from cell to cell.
