Ralph Johnstone
Recently we upgraded from a two bladed (15 X 12) to a three bladed (14 X 10) prop on our Hunter 310. The engine is a Yanmar 2GM20F.The new prop design was done by a professional shop. The original prop had realtively narrow blades while the new prop has blades of a larger area. The main reason for the change was to eliminate vibration and this it has done admirably. There has been no change in speed at the usual 2900 RPM which is 5.5 knots. The question which arises is this: is there some rule of thumb to determine just what the loading is on your engine at, let's say 80% of MAX RPM = 2900 RPM. Is the engine actually loaded to 80% or is it just loafing along due to insufficient pitch ? How can one tell ? The big problem here is that most sailboat engines (and this one) don't have a throttle but actually have a governor adjust which we refer to as the throttle ........ so the enigne turns over at the same speed for the same "throttle" position if you are in gear or out of gear. Any ideas would really be appreciated. Regards, s/v Island Hunter
