Over Heating a Yanmar 3gm30F
NCBrew
Feb 22, 2010
78
Hunter Hunter Legend 35.5 9335 Albemarle Plantation, NC
What can the possibilites be for overheating a 3GM30F ?
Jan 7, 2011
5,593
Oday 322 East Chicago, IN
Many different things….
But a few questions to help us narrow things down…
1) are you getting good water flow out of the exhaust? Lots of potential causes, and this would certainly cause overheating.
2) Do you have AF in the heat exchanger? Is there some AF in the overflow tank? I bought a boat and was motoring it home…a30 minutes into bashing. seas on Lake Michigan, engine alarm went off….engine overheated. Nursed her into the closest port, and found nothing in the HX. So I know this can cause Heating issues.
3) is the bottom and prop fairly clean? Overloaded ngine could run hot.
4) Any smoke, oil, or other stuff in the exhaust? Something mechanically gone wrong in the motor?
Give us a little more and we can narrow things down for you.
Greg
Jan 7, 2011
5,593
I wasn’t identifying the reasons yet.….just trying to narrow down the possibilities before we got too deep into the causes…
but good info.
Greg
939
Hunter 27 Pecan Grove, Oriental, NC
I had a 3gm30f on a prior boat. It always ran at around 180 degrees at cruising speeds. Slowly the temp began to creep up over several months. Eventually I had to reduce the rpms to 2000 or less to keep at or below the 180 mark. It turned out to be a blockage at the top of the mixing elbow where the raw water enters. #2 on Hello Below"s list of possible causes.
Likes: kloudie1
Sutric
Jun 24, 2021
41
Seafarer 26 Carlyle IL
Having really overheated mine due to the water pump impellor destroying itself I would say the possibly is pretty good.
kbgunn
Sep 19, 2017
231
2005 Hunter 33 Lake Lewisville, TX
I had an old hose on the fresh water cooling loop that would leak coolant went the engine got up to pressure at normal operating temp...low coolant level will definitely cause a high temp alarm.
Jun 1, 2016
162
Hunter 28.5 Lake City, MN
I have a 2GM20F that started to overheat on me quite a number of years ago. I found that the antifreeze coolant was low, so I refilled it, but it kept going down (slowly), but it was not leaking inside under the engine. Long story short I removed the Heat exchanger, thinking there was a leak in there. I also used an antifreeze flush to clean out the system. When I put it back together with new gaskets and O-rings, it still leaked. I put a recommended amount of Barr’s Stop Leak in and the problem has never come back.
I used some stop leak on a car heater core and that prove to be a permanent fix as well.
Sir Michael
