Timm: There are two types of configurations for the foot of the sail - loose footed and bolt rope. You can mark the extremes of both with stickers you can buy from West Marine. On the bolt rope set up, the extremes are easy. Release the outhaul and and let it go as far as it can. That's one mark. Pull it back as far as you can and that is the other mark. Also, place a mark in the middle.Loose footed is not so easy. The aft extreme mark is easy as it is as far back as the clew will go. To determine the forward extreme you have to understand draft depth (belly). The problem I enounter on every loose footed boat I have been on is that the skipper induces too much belly in the sail. With some things in life "more is better" but it is not the case with draft depth. The more belly you induce into the sail - after a cetain point - makes the sail less and less effective. In fact, it becomes counter productive. Draft depth and draft position are measured in the form of a percentage. How do we determine the percentage? Easy, just measure the foot of the sail. This is not the scientific way but it will get you into the ball park. Assume the foot is 10'. If you put 2' of belly into the sail that would equate to 20%. 3' would be 30%. 3' would probably be the maximum amount of draft depth you would ever want to put into a sail.SOoooo, at the dock, raise your main and locate the middle of the foot of the sail. Then release the outhaul and pull out the foot of the main. Now merely measure say 3' from the boom to the foot of the sail. Mark that spot on the outhaul. That is the forward extreme. Also mark the halfway point.If you are loose footed, the next thing you want to do is go out sailing and experiment. You just can't mess with the outhaul only. In other words, you have to set up the jib properly for the wind conditions you are sailing in. Additionally, you need all the other controls for the main set properly. At that point you can start playing with the outhaul. There is an optimum position for the wind conditions you are sailing in, which you have to note for future reference. Unfortuantely, every time the wind speed changes so does that position.Timm, I hope I've given you the info you need, but if not just fire another question away.
