Hull type determines Max speed
Bill,Since the 26C is a displacement hull and not a planing one, it has a maximum hull speed which will not improve much with more power. 5-10hp is good for this boat. If you sail in the ocean, I recommend the Tohatsu 9.9. It has an ultra long shaft, electric start, 4 stroke with hi-output alternator. Very sweet engine for this boat since it is a real pain leaning over into the well to pull a rope starter. Doesn't come out of the water in swells. The alternator charges the battery and runs nav lights, etc.
