O'Day 25 was originally "rated" for a max of 15 HP. That was a 2-stroke size, but the OEM bracket was certainly more than strong enough for the thrust of a 15 HP, and so the transom would have been built to handle that load. I'd want to inspect the area inside the transom where hte bracket mounts, what condition is the plywood backing in? How well were the bolts bedded? After 35 years it may be time to remove the bracket and at least apply new sealant around the holes....... and if any doubt about the conditio nof the plywood backing, replace that. Then you know it will handle the new outboard, and replacing the bracket (even if you replace the 6HP with another 6hp) now will really improve your peace of mind.
A friend of mine used to have a 1979 O'DAY 25 fin-keel model in Apponaug, he had the OMC 15HP ZEPHYR inboard. Great boat, but the slip that he was in at the time I joined him for a sail wasn't really deep enough for the 4'6" keel....... well, actually I seem to recall that there was enough water in the slip, just not enough in the approach to his slip! We ran hard aground (in mud) about 10' from the slip! Enjoyed our lunch while we waited for the tide to come in....... and waited, and waited.... I had to leave around 4 PM to teach a Boating class that evening, and had to jump over to the pier (just made it!) when I left. I hear that he finally slid into the slip the rest of the way 30 minutes or so later.
To those wondering, Warwick, RI is in the Northern end of Narragansett Bay.
