Outboard shaft length
100
Beneteau Oceanis 48 Casco Bay, ME
I have a new 240 and can't wait to get out. I do need to pick up an outboard (8HP, 4 Stroke)and was wondering what suggestions folks have for shaft length. Any input on alternator capabilities would be great too. For short trailer trips, is it necessary to remove the outboard from the transom? Best regards
Aug 11, 2006
1,446
Hunter H260 Traverse City
Outboard Length
Lots of discussion on this subject in the archives, but the consensus is that the longer shaft helps reduce cavitation. I have the 25" shaft on my H260 and have only experienced cavitation a few times in heavy weather. Some people take the engine off to get more tongue weight (10 percent plus is desired for proper towing). However, I think moving the boat forward on the trailer makes more sense if you need more tongue wt. Hunter expects you to hang an engine on the transom and designs it to handle the wt. Take the engine off and put it back on a few times and decide for yourself. If you can find it at a decent price get the alternator, power tilt, long shaft; you'll be glad you spent the extra money. I have a friend with the honda 9.9 and it hums like a sewing machine and always starts the first crank. My 4 yr old Evinrude weighs twice as much and is a Model T by comparison.
Sep 25, 2003
100
Thank you
Thanks for the info. I am new coming and will search the archives also. Cheers
