So I just spent a small fortune getting my outboard repaired. The salt water had corroded the water tube and it needed to be replaced. I have been asking what I should do to prevent this from happening again. There are many opinions. I know about flushing the motor with fresh water - etc., etc., but my big question is do you leave the outboard "down" so the lower unit is in the water all the time or do you tilt it up when on the mooring?
Thanx in advance.
Thanx in advance.
