I bought a Gamefisher 7.5 hp outboard which ran fine when I bought it. I replaced the fuel line that came with it wit a new 3/8 fuel line. The fuel line I took off of it was smaller than the new one. The problem is that now when I start it it only runs for a few seconds. If I take off the fuel line it will run for a while, until the fuel in the bowl runs out. My question is can the larger size fuel line be causing me problems? Also on the quick connect going to the motor there is no hose clamp. Could that cause problems? e.g sucking air? Any help is greatly appreciated. THank you
