Outboard power setup
Oct 30, 2019
10
Hi guys,
This is a question for your guys that power your Vega's with outboard
motor only. What motor power do you have and is it satisfactory. What
shaft length motor do you use. Also what do you do with empty hole
from propeller shaft? Any fail-proof ideas? And are there any other
isses to address?
Thanks everyone for your help!
Arek
Vega #993
Nov 12, 2008
20
Use an 8 horse 2 stroke Johnson long shaft. More than enough. As for
the old prop shaft hole, its filled and glassed. I like the weight
savings and the extra room for storage. I don't like pulling the OB,
especially in a pitching sea. Hence im considering a well or
re-powering with a beta. Also considering a newer 4 stroke since they
are quieter, and lighter. Also better on fuel.
Nowell
s/v Aquila #176
Jul 6, 2007
106
Hi Arek;
I use a long shaft Yamaha 6 hp 2 stroke engine, the proper was changed to a different pitch than the original due to the length of the boat (aparently the original engine propellar is designed for an under 20 ft hull).
The hole I blocked it at both ends, the insede part I used a rubber tube over the properler shaft casing tightened it with two stainless steal hose clamps then put a bronze cap on the open end of the rubber hose (also using two more hose clamps) .
On the outside of the hull I used a less sofisticated method, a rubber sheet folded a couple of times and then used a smal 1 inch end of a broom and hammered this in (the bit of wood remains in which should be asily hamered out from the other side just in case someone desides in the future that they still want to use it), so far no water has permiated its self in.
good luck.......
May 1, 2000
12
I used a round cork that I tapped about 3 inches into the shaft hole and filled the 3 inches with 5200 adhesive that was glassed over. Has lasted over 10 years no leaks. Should be easy to remove. Zo
Oct 30, 2019
574
So, how do you find she handles with the outboard? Are you doing mostly coastal, blue
water or lake sailing? In your opinions, what are the pros and cons of the outboard? If you
had to do it all over again, would you.
As you can see, I'm back from the BVI. Great to see all the stuff I missed (well, technically
I didn't miss it).
Take care,
Jack
Jul 6, 2007
106
There are some already discussed prior emails on pros and cons.
I do most of my cruising out in the english channel (which is niether nor), but take the outboard out of the braket (if on sails longer than 25nm or if is going to be rough since it helps balance the boat, giving about .3 knts of extra speed).
I am in two minds if I would do it again,I worked out that I would need to use the engine about 6K Nm to be able to justify an inboard in price (due to fuel consumption) which at my planned rate of engine usage is about 10 years worth of sailing (currently it is at about 25 years).
However the engine I got can be fixed and maintained by anyone (ie a non mechanical oriented person like me :)) and the spare parts can be found anywhere in the world (my main consideration).
What I would do different is get the most expensive, best set up, engine mounting I can find since the cheepo one I got broke off (at some welded axis) when sailing upwind on a F6-F7 with 60 nm of fetch (about 3-4 meter very steep waves) or just strengthen the braket by removing welding and replacing it with decent size screws which can be checked on a regular basis.
I do think that is mostly down to how much time you got and the area you will be sailing in.
If you dont have an issue with taking a wille in arriving at your destination then even a sculling oar should do! but if you got to get there by Sunday, the an inboard is the way to go.
Similarly if you are planning to stay in relativelly developed areas (ie eastern caribbean) an inboard should not keep you too long in harbour should it deside that it needs a new fuel pump, whilst if you are in a place like guyana good luck getting a pump in less than 4 weeks.
Any way my 2p
Oct 30, 2019
1,459
Hi Arek,
From my experience with outboard motors:
Pros:
- Quieter
- VERY economical to run (4-srtroke)
- Easy to remove from boat for service and repairs
- Frees up storage space under the cockpit
- Easy to maneuver boat, and even back up!
Cons:
- Prop tends to come out of the water in heavy seas
- Motor can get dunked in heavy seas
- Gasolene (Petrol) not as safe as Diesel to carry onboard
- Easy to remove .... for others :-(
That said, my outboard experiences are with two non-Vegas.
I would not even consider getting a 2-stroke, even though they're a bit
lighter.
Any motor, inboard or outboard, requires regular maintenance to stay
trouble-free. My personal preference is for the inboard Diesel. My
little Yanmar is a gem. I fuss over it, and keep it clean and serviced,
and it always comes alive when needed.
Peter
#1331 'Sin Tacha'
