Specific to the engine and the bracket
there is no one "right" way to mount an outboard bracket. Although most brackets should be mounted with at least four stainless bolts to the transom (with backing plates of some kind), where exactly the bolts go is a function of the bracket's span of motion and the dimensions of the outboard. You need to make sure that the prop will be underwater when the bracket is at its lowest setting, and that you will be able to still reach the controls from the cockpit (unless you are investing in remote controls). If you like to tilt the engine in addition to or rather than moving the bracket up and down, you will have to make sure that the bracket is far enough away from the transom. This will probably require making a spacer block and mounting it between the transom and the bracket. I am unfamiliar with the 272, so I don't know if it was designed to take an outboard bracket. If it wasn't, you should also beef up the transom where you intend to mount the bracket. I would consider epoxying some marine grade plywood to the interior wall of the transom to the spot. Good luck.
