E
Eveningstar1
I just purchased a 1980 O'Day 19, and want to mount a 5-6 HP 4-stroke outboard. It came with the lightest duty Garelick outboard bracket mounted on a small transom adaptor. The boat was used in salt water, in Florida, and then towed to North Idaho, where it has been in storage ever since. As a result, the outboard bracket is badly corroded, and falling apart. Due to the corrosion of the outboard bracket, I would like to check the integrity of the mounts for the transom adaptor for salt corrosion and/or install a larger adaptor. But I am baffled by how to reach the nuts that secure the transom adaptor, inside of the transom. Has anyone else had experience with this? Also, none of the outboard brackets that will fit the existing adaptor are recommended for use with 4-stroke motors. Fulton rates some of their brackets for both 2 and 4-stroke motors, but then they say specifically that the brackets are not to be used with 4-stroke motors. Can a 5-6 HP 4-stroke, weighing 57 pounds, really be that much more stressful on a mounting bracket than a 20 HP 2-stroke? I am curious about what solutions other day sailer owners may have come up with for this. I could install a larger bracket, rated for a 4-stroke, if I could find a larger transom adaptor. Does anyone know of a source for something like that? Any help or advice that you can offer will be appreciated.
