I have an older 8.5hp merc 2 stroke (circa 1985). It still runs strong but has a problem with the throttle linkage.
I don't have any pics of the problem area, which I'm sure would help to explain the issue, but here goes.
I'm sure most outboards have a similar linkage setup, the throttle handle turns a gear that converts the horizontal rotation of the hand grip to a vertical shaft that controls the carburetor.
The problem is that the square hole of the gear that rotates the vertical square shaft is rounded so it does not actually rotate the shaft anymore.
As a result I have to pull the cover off and manually control the throttle arm, putting my fingers near the spinning flywheel of death.
So the problem boils down to repairing the round hole that should be square.
What I've come up with so far is this:
1. Get replacement parts. Problems is it's an old motor plus I tried to remove the square shaft once, and although I consider myself a fair mechanic I could not figure out how to actually remove the shaft form the engine - it seems to have been either been crimped on or slid on while the motor was detached from the lower unit.
2. Hook up an external throttle. This bypasses the linkage problem as the throttle cable hooks directly to an arm on the square shaft - but I don't really have a place in the boat to mount a throttle handle.
3. Repair it. This is what I want to do, I need to strongly attach the round hole/square shaft union. I've considered JB weld, drilling and pinning, inserting shims, clamping, and combinations of each.
I'm sure the forces are pretty high on the joint, plus the environment is oily and experiences a lot of vibration.
Anyway, if anyone can think of something I have not I would like to hear it.
