WaterSki Behind Your Oday 25
My boat partner/brother in law and I arein our mid fifties. Our old pull startmotor was out to kill us for sure. Theold 8hp was also a real polluter. Being ecologically minded we wanted a clean4 stroke, a new one with an electric starter. So we coughed up $2400.00(twice what a new 2 stroke costs)for a new 9.9hp 4 stroke " Sail Power " long shaft Evinrude. It's huge,it takes two to lift it and three to set it on the old braket. Once on the braket, it took a 3way purchase with 2 blocks to "get it up". I ordered a new bracket "especially made for 4 stroke motors". Of course it didn't fit the old screw holes and we made an angled spacer out of mahogony because the old fiberglass one didn't work. I put in a new plywood and aluminum backer plate inside the hull. Everything back in place, we heaved the thing on the new braket and lowered it toward the water. The damn prop was barely below the water. The installation was by the book, so how could the prop work if it wasn't submerged? I hooked the leads to the battery and pushed the start button and the motor magically started. I put in in reverse, the prop barely flicking the water, then into forward. Slowly I gave it gas and then again as if by magic, the prop dug into the water and the whole stern and moter lowered into the water, we were moving! Some how the horizontal fins above the prop made it suck down into the water. We now make a rooster tail going 8 knots. We really haven't tried to waterski, and I literally cut the end of my left index finger off and had to get it stiched back on while lifting the motor to the up position,but now people ask " is that thing suppose to be on a boat that size". I say " Yes it is, besides, we couldn't get it off anyway !
