Outboard motor mount?
Apr 8, 2016
18
O'day 23 Kingston, TN
Continuing refit on 79 Oday 23'.
The old outboard motor mount is on the port side, and yet I see many on the starboard side. The question I have is which side did the manufacturer put it on, or was that simply an owner addition? Which is the preferred side? Plan on two house batteries which will go on port side... would you which Bracket to starboard?
Regards to all...
May 24, 2004
7,164
CC 30 South Florida
Have had boats with mounts on either side and never gave it a thought to switch them. As far as batteries I would not place them on either side, we keep a Starwind 223 and two batteries were located in the center under the companionway. Check the rating on that mount as when the boat was built the average weight of an outboard 9.9HP was around 65 lbs. Todays electric start 4 stroke engines average around 95 lbs.
Apr 8, 2016
18
Thanx for input... on another thread someone suggested starboard side was reinforced while the port was not... why I was wondering...
Jun 2, 2004
1,941
Oday Day Sailer Wareham, MA
When the O'DAY 23-2 was built (1977-85 model years) the average weight of a 2-stroke 9.9 would have been around 75#. As to which side to mount outboard on, One factor is transom re-enforcement, If original was on Starboard side, plywood backing might be molded in there, or maybe backing was added on port if that was aftermarket. I have always had my outboards mounted offset to port, and that worked well for me. However, one thought is that an off-set outboard affects turning, so if it is advantageous to be better at turning to port, mount outboard to Starboard. If you more often need to turn sharply to starboard, mount motor to port. With my outboard mounted to port, the boat will turn better to starboard under forward power, and if backing, turn better to port (that is In reverse, the bow moves to port, helpful as I back away from my mooring line located off the starboard bow.) With most motors, the tiller is offset to portside of engine, shift lever either on front of motor of on starboard side. So, with outboard mounted to port the OB tiller is farther from boat's tiller and shift is between OB and rudder. Mount Outboard to starboard and tiller is closer to the rudder/tiller of the boat and shift is away from tiller (unless on front of motor as some newer ones are). I like Outboard on one side of boat, battery offset to other side for balance, but if you have electric-start and/or a battery charging coil, how long are the cables? Will they reach from outboard to battery, or will you need to extend them? I like the idea of locating the battery amidships under the companionway, but that may be a long run for the cables, plus the O'DAY 23 has a built-in ice-box there (does anyone actually use it as such?). I think originally, O'DAY located the battery box in the cockpit sail locker.
May 24, 2004
7,164
CC 30 South Florida
I may have failed to mention that our two stroke Nissan is pull start with no alternator so no need to run wires from batteries to motor.
Apr 26, 2015
663
S2 26 Mid On Trailer
Stick your head into the locker and look at the transom. On my '78 it's obvious which side is reinforced. Starboard side 3/4" plywood bonded in, port side 3/16" to 1/4" fiberglass. At 5'10" , 165lbs and 62 years old I can get down inside there.
I moved my batteries under the V berth. These things already drag their ass without any extra weight.
Apr 8, 2016
18
Been thinking about where to relocate batteries so can still have access to area under cockpit... thanx again
