Go long
A standard (short) shaft outboard might be marginally acceptable, but I can't recall ever seeing a mounting arrangement where it was anything but barely functional. Wakes, waves and other natural forces often pull my long shaft out of the water far enough so that the water intake is briefly exposed, and that's on calm days in Long Island Sound. In choppy conditions, the prop has come out of the water completely. In smaller boats, this effect is even more pronounced, as they will pitch fore and aft more readily than a larger, heavier craft. In fact, I will often start my outboard to let it warm up as soon as I get to my boat. When I go forward to hank on the jib, just my weight will draw the bow down and stern up enough to bring the intake partially out of the water. Part of the problem is that I have an old outboard, and it seems that the definition of "long shaft" has changed over the years, with the long shaft models getting longer and longer. My long shaft is not as long as some that are offered today. Go long, and compare the lengths offered by the different manufacturers.
