Last September on a trip to Dana Point, my outboard quit on me. I figured it was a fuel issue as I have two tanks with one of them empty. However, I had the valve open so I suspected I starved the engine. I was able to resolve the problem quickly and resumed the trip. Coming back home there were no issues.
This March it happened again. But this time both tanks had fuel. It took me over an hour to get the engine started again but had to be towed to my slip for fear of the engine failing in a busy harbor with very little wind.
This morning I fired up the engine to prepare for another trip on the 21st. As a result of the March trip, I changed out the fuel water separator. The engine ran for a few minutes then sputtered dead. I tried to start it several times and it would not. After pulling out the choke the engine again came to life. When I put the choke back in the engine dies.
There were a few other things I did to eliminate a fuel issues. I wish I could use an external tank but the engine I have does not have a standard fuel connection. Yamaha changed it to a round lock on type and not the prongs. I cannot find a hose that has that connection. I have looked but probably not very hard I will admit.
So back to the choke / no-choke. Now we did have the fires not too long ago but I never ran the engine so I am sure I did not ingest any particles. But it is possible. Other than that, does anyone have any suggestions? I will go back to the boat tomorrow and continue with the trouble-shooting. I really do not want to take the motor off the boat and take it back to the dealer. It is a lot of work to do that, but IF I have to I will.
I am now open for suggestions. Thanks
