Outboard for Ospray
4
Oday Ospray Scarborough
Been looking at new 4-stroke outboards, but I've always owned 2-strokes and not sure what is appropriate for this boat. I think I want a minimum of 4 HP, would like to to have F/N/R shift and remote tank option, and probably a 20" shaft. The Honda 5 HP, Yamaha 4 HP and Nissan 4 HP are what I'm looking at, anyone with experience with any/all please comment.
Thanks, Pete
May 7, 2006
249
Catalina 28 Mark 1 New Bern
Pete as a reconmendation I would consider the merc 6. Ithas both an internal. And is capable of taking an external tank I have this set up and I love it.
Jul 28, 2011
4
I have a 3.3hp Merc on it now, a 6hp would be terrific. I should probably forgo a 4hp since the gain would be minimal over what I have now.
Jun 2, 2004
1,944
Oday Day Sailer Wareham, MA
Anything more than 4hp on an OSPREY is a waste of $$. Even 4 hp is almost more than you can really use, but 4hp is about the smallest that will have FNR and a remote tank option (why I have a 2-stroke 4hp Johnson long-shaft on my DS II, FN only though). Going to a 6 HP outboard, especially a 4-stroke means a much heavier motor than the 15'9" OSPREY was set up for. I'd be more inclined to go with a 2 HP HONDA or 2.5 HP Merc/Tohatsu/Nissan/Suzuki, even though they don't have full (FNR) gearshift or the remote tank option. If 2.5 is not offered with longshaft, then the 3.5 hp (2HP Honda does come in 20" shaft).
6 HP will more power than can be used, why have a 6 if you can't go more than 1/2 throttle with it (maybe not more than 1/3?)?
HONDA 5 hp might be "OK", but is still borderline oversized for the boat. However, it might be a good compromise....... I'd consider a 4hp first though. O'DAY suggested a 5hp or less, but those were back in 2-stroke days.
My Dad had a 3 hp on his old FALCON (the OSPREY was a Falcon clone), and the 4hp on my DS II is plenty of power, could MAYBE handle a bit more....... but don't need it (4hp creates a pretty good wake @ 6.25 knots on a DS II!).
Going from a 3.3hp to a 4hp will be more of an upgrade than you think, you will gain the remote tank, full gearshift, and most likely, better vibration damping, and long-shaft (again, reasons why I have a 4hp Johnson, not the 3hp Mercury of the same vintage, 2001 model even though I still only have FN shift).
Jul 28, 2011
4
I haven't clocked my 3.3 but I bet I get around 5-6 kts out of it in calm water. Noticably faster than the 2.5 Evinrude I had on it and the F/N the merc has is vast improvement for launching and recovering, almost renders a reverse gear moot really....but I'm thinking a new 4 stroke is likely more reliable, which is re-assuring.
