Filler material
Ted, you might think I'm a little nuts, but there's a product at your marine store known as Marine-Tex. While it's not fully intended for the purpose, it's very versatile material and once it sets up, brother, it's harder than concrete! I know of a case where a guy fixed a crack in his block with the stuff and then used a cylinder hone to smooth it out, put the engine back together and it ran pretty much ok. It's a two-part mix and you have some working time with it. I would use it like body putty -- Bondo -- and use a plastic squeegy to make sure you get it in the pits and to get it as smooth and as flush with the surrounding metal. I would try to work it as carefully as I could because once it cures, it'll be pretty tough to sand. It's pretty waterproof and the pits, by their nature, are going to have some "tooth" to them so the material can get a grip and hold on once it sets. Now, this is a little weird, I know, but I think it will work. I would do it to my motor under same circumstances. Once the stuff cures and you've gotten it pretty smooth with the surrounding metal, you'll be able to paint over it ok.By the way, it's Zinc Chromate; not Chromide...just saying that so you won't go off looking for the wrong stuff. Use a couple of thins coats which is better than just one heavy one but be sure to cover the metal completely. Let me know how things turn out.Also, be sure to check your anodes like the other post suggested. It sounds like to me that you are getting some electrolysis damage, so just be on the safe side you want to check that.Regards,Bob
