I posted this in the Engine and Propulsion forum but didn't get any hits. So I thought I would try here.
Having an issue with my '11 9.9 Outboard Tile and Trim. The motor is in the up position and will not budge. I was told by the marina personnel that the docks were hit pretty hard with swells and white caps. I see a lot of salt residue on the motor mount. So I am sure that salt got into the piston freezing the tilt-n-trim piston rod.
So some thoughts. I plan on using PB Blaster Penetrating spray on the piston rod. Hopefully that should at least break up anything blocking the piston movement.
There is also a plug on the front of the piston. Look like a fill port for fluid. The guys at the marina told me to also check for corrosion and possible fluid leakage. I didn't have time to do that but I think if the fluid was leaking wouldn't the motor eventually move down due to gravity? Or am I not thinking straight on that one.
So tomorrow I will spray both the piston rod and the plug to try and breakup the salt build up. If you have any other suggestions while I am down there let me know.
The plug by the way is pretty well frozen but I am sure with some determination I can free it. I think if I do that the motor should move in the down position by itself. Would that be a true statement?
Thanks for any thoughts in advance.
