Outboard Battery Charging
Sep 24, 2018
4,571
Catalina 30 MKIII Chicago
I have an Evinrude 9.9 which I just replaced the regulator/rectifier on. Do these things actually regulate charge/voltage or is it just a bunch of diodes acting as a rectifier?
Mar 6, 2008
1,505
Rectifier simply means diode. It makes the current flow only in one direction. They do not regulate the voltage or current.
Nov 6, 2006
10,221
I think that there is a simple regulator built into the newer motors that limits voltage. The amperage is usually kinda small and needs a bunch of RPM to get anywhere useful. the older ones might do around 6-7 amperes at 3000-4000 rpm, the newer ones can get to 10-12 amperes. Just guessing without a year and model number for the engine.
If you want to know the voltage coming off of your alternator, hook up a voltmeter (multimeter) to the leads and then turn the motor on. You should see something close to 14 volts.
Sep 14, 2014
1,292
Catalina 22 Pensacola, Florida
hook the leads to the battery , run motor and check at terminals, only way to determine voltage output is under load. Voltage regulator does not put out voltage if does not detect load.
Likes: rgranger
Sep 24, 2018
4,571
The motor is a 96. I measured ~16v with no load connected so I'm assuming there is no voltage regulator and Im guessing there's no caps of any kind to smooth things out?
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
Went to owners manual it only said keep battery charged, connections clean and don't reverse connections. And BTW don't touch the wires. Again bitten by another assumption met by a paradox if the manual does not say how much it charges does that automatically mean it does not have a charging source device.( Yamaha 9.9 tilt/start)
Nov 6, 2006
10,221
Lots of the older regulators cannot reduce their open circuit output voltage; they need a load to be able to function. Hook up the battery and measure volts and amperes .. First read the battery volts with it connected but engine not running, then read volts at the battery with the engine running at a fairly high speed in neutral; you should see something around 13 -14 volts.
They don't have "smoothing" capacitors but it may have several magnets in the flywheel to make the pulses close together (somewhat smoother).
