C
Catalyst
We have been working on odors associated with THE HEAD for the entire year we have owned our boat- we had a leaky aluminum tank - which turned out to be most of the smell. But, has anyone else had trouble with hose clamps biting into the hose and making holes? I found one that looked like a vampire bit it- guess we overtightened.... Could this be the cause of the persistent odors? We have replaced EVERY part of the system (holding tank, macerator, ALL hoses-with the good stuff). We had a leaky PVC fitting (not glued completely) which we also replaced after the new install- and it STILL stinks like sewage (and the smell is coming from this area). Have cleaned the shower sump and the bilge completely. Use only KO in the tank and CP in the shower and toilet. Even installed a Yvalve once I figured out what it was and read Peggie referencing it so many times-realized we only had a T.We had new tank made custom (Triple M ) polypro... used Sealand special-ordered fittings (straight instead of the elbow- but the lines do not seem to kink), and teflon tape on the PVC fittings. Oh, and we do not have a Discharge Vented Loop- only an intake vented loop. The 1 1/2 " hose from the toilet goes straight into the tank (5'run downhill)- Is this bad???Could part of it be odor coming back through the toilet? We have an old Jabsco (new joker valve in the last year) HELP.... I am ready to jump overboard. Thanks so much for your help, everyone... boat owners need a support group
