Recently experienced a problem with my fuel.
Was just heading out to cross the Strait of Georgia when the engine began to sputter. At full throttle could only manage 2000RPM. Occasional the engine would race then settle back to 2000RPM.
Tank indicator was showing 1/3 tank.. and this seems to have been reliable up until now.
Note that the Espar heater and Northern Lights gen set both seemed to be running fine, but I didn't run them for a long time.
Decided it was a fuel issue and when under sail proceeded to check the fuel system. Bled Racor filter bowl (seemed to be watery diesel) then the filter right at the engine. Fuel at the Racor looked better after the bleeding... so pressurized the system - note that there still seemed to be some bubbles at the engine filter when pumping... couldn't get steady fuel. Decided to start her up .. ran smoothly all of 30 second and then she died. Tried to pressurize the fuel system again, but no luck.
Removed the bowl from the bottom of the Racor again.. then opened the fuel tank stop cock to see if fuel was freely running to filter... after about 100ml of fuel the flow stopped. I removed the IN line to the Racor and blew the line to see if I could push fuel back to the tank... was a bit hard at first, but I could clearly feel I was blowing into the tank after a few hard puffs. ... and still no fuel flowing back down the line to the filer.
Became suspicious about the tank indicator so tapped on the poly fuel tank to get some idea whether there was fuel in there or not.. seem to be quite low (very hollow sound).. but very hard to tell near the bottom of the tank where it is curved. Being daylight I was unable to see where the fuel line was in the tank by shining a light on the top of the tank and looking at the side of the tank in the transom locker.
Wound up putting the zodiac in the water with my 9.9 merc and once we reach the other side (late because the wind was slackening) used it as a tug to get us to the slip in the marina. My guests were impressed by this manoeuvre, but I was pi%$ed off.
Next morning, convinced that the tank WAS empty I proceeded to fill the tank, but was surprised to find that it was topped up at 225litres!!! that's about 150litres short of a full tank. BTW, I always HATE filling the tank on the Hunter 466 because the tank vent and fill port are on the outside sloped part of the hull. I guess this means water can't pool around them (a good thing), but it also means any misjudgement in your fueling and the diesel foams all over the place.. including into our pristine BC waters!!! I visually verified that the tank was full when that evening I shone a light into the top of the tank and I could see the top of the fuel just below the top of the tank.
The next morning I pressurized the fuel lines as I've always done before (got fuel only - not foam - at the engine filter bleed nut by pretty much pumping the RAcor only) and started her up. Engine ran like a charm all the way home... 300PRM and 8 kts motor sailing the whole way with not so much as a hiccup.
So what is going on?
I do not know the mechanics of the fuel pickup in the Hunter 466's 100 gal tank. Is it on some kind of float system that rides on top of any water that might be in the tank, suggesting I have 150 litres of water or crappy dense diesel in the tank?
Note that a similar thing happened last fall, but when I bled the system after draining some water from the filters (changed fuel filters as well as they had not been changed sine I bought the boat in early 2006) all ran fine until this weekend.
Have been trying to find info about this on the net..no luck so far.
