What Motor?
Herb: What Manufacturer and Model Motor do you have?As Stu suggested, there is almost certainly a screw that you can just tighten that will increase the friction and keep the motor from rotating. If you look, you will find it. Usually they have a spring on them. You certainly do want to do this. I only move my motor when I am in a really tight spot. So when you find the friction screw, adjust it inward and try to rotate the motor with it's tiller. Keep adjusting it until it has enough friction to keep it where you put it, but so that it can still be moved if you want to. If you ever have a rudder or tiller failure, this is how you steer the boat back to your slip. Aldo
