When climbing up the swim ladder barefoot on my Legend 45, the stainless steel round ladder rungs hurt our feet. Has anyone tried to make teak planks that fit over the rungs? If so how did you attach to keep the planks from turning when you step on them? I've thought of cutting semi-circle holes in the ends of the planks to catch the vertical bars, and then to use brackets similar to those used by electricians to secure conduit, from underneath, but this won't keep the treads from turning slightly while climbing. An alternative would be to thru-bolt them to the rungs with stainless steel 1/4" bolts and washers.Has anyone done this? How successful was it?Thanks,DanO'side
