Peter Brennan
Uh oh! I see this forum is sponsored and moderated by Adler-Barbour. Does that mean we are not allowed to discuss and perhaps recommend other makes?We had an Adler-Barbour in our O'Day 37 and it worked just great. But the aluminum to copper joint in the refrigerant line near the evaporator broke (I suspect rough handling by the boatyard doing after-fire repairs) and it was prudent tio replace the entire ancient system.I replaced it with a Frigoboat keel cooler system. This uses essentially the same Danfoss compressor and the evaporater looks the same as the A-B unit. But the condenser is a copper tube inside a sintered bronze ingot very like a ground plate which is attached to the bottom of the hull with a through hull. One has to drill a hole though the bottom of the boat, a nervous-making activity. There is no fan and no pump. Only the compressor runs. I am very pleased. The unit draws about five amps when running but seems to run only sporadically. Twenty four hour battery drawdown is less than half what it used to be.
