Common problem
Most 34s have only minor blister problems compared to other production sailboats. What you have is acne, not melanoma, at least if your blisters are the same as most I have seen on this vintage Hunter. They should be looked after, but will probably require less than the full gel coat peel and replacement that some will try to sell you (cost equal to a third the value of your boat). There is plenty written in these archives on this subject so I will leave you to research and learn on your own. I have been repairing blisters as they appear for the last 15 years and can report that at this years haulout (after two years in the water) there were none. I barrier coated when the boat was two years old and showed its first acne. I have reparied 50 to 80 blisters, as they appeared, in the years since. Repairs are simple, but time consuming.
