Riding at Anchor
Our H340 is also quite "active" not only at anchor, but also at moorings. As we look around our harbor, this is typical of many newer boats, most of which, like new Hunters, have relatively light displacements and lack long keels. (There is a Westsail 32 in the harbor that dosen't move at all at the mooring; also doesn't move under sail with less than 20 knots wind!)More scope will likely decrease the period of the swing, but not necessarily the angle. We have found an anchor sentinel (20 pound) to reduce movement in relatively light wind, but probably wouldn't help much in anything over 10 knots wind. We have purchased an "anchor riding sail" for our boat. This is a small triangular sail raised on the backstay (on our boat it will be on the topping lift; no backstay) that helps greatly to keep the boat nose into the wind and dampen the tendency to wander. We haven't had a chance to test it out yet, might not get a chance this year. We will post the sail dimensions, a picture, and our experience with it when we get to try it.Carl and JulianaH340 s/v 'Syzygy'
