the marine store sells a blueish fuel that is advertised to be specifically for stoves. The guy there says it will burn hotter. Naturally .
they get paid to tell you stuff so you feel like you need to buy their more expensive product...
100% alcohol is all it is.... "everclear" grain alcohol (ethanol) will also work cuz its 100% alcohol....
the blue stuff (and other colors as well) is denatured alcohol, (but it can also be clear) and has a small amount of another solvent added to it to make it unusable for human consumption so it can be sold on the free market for other uses, such as stove fuel.... methanol is the most common additive which also 100% alcohol but it is wood alcohol and is poisonous...
an alcohol that was denatured using acetone or MEK can give off more smell as it burns, but can be used.
the burning of 100% methanol can give you a severe headache so its not recommended to use it as stove fuel, but the small amount that is added to the grain alcohol is in such dilution that there are no worries of headaches unless you have an abnormal sesitivity to it...
sandpiper10471....
I am surprised you cant buy generic denatured alcohol in ontario. it is such a common solvent for all different type of uses. all hardware stores, home improvement stores, walmart type stores and a lot of grocery stores carry the stuff here in the states.... rubbing alcohol (denatured with isopropal) can also be used as stove fuel, but it
usually has a higher percentage of water added for dilution, which isnt so good, but sometimes it can be found at 100% alcohol... (Isopropal alcohol is a much better solvent than the other two, as a cleaning product)
methylated spirits is always ethanol with methanol added as the denaturing agent.... its the second best type of denatured alcohol on the market over using pure ethanol (grain/drinking alcohol) for use as a stove fuel.
