original non pressurized alcohol stove question...
May 30, 2006
1,075
So i was cooking my tea and had a thought....That stuff inside the canisters, that absorbs the alcohol and is very flame resistant....What is that?Should I be scared?groundhog
[Non-text portions of this message have been removed]
n4lbl
Oct 7, 2008
307
I'll look later today and see if I can guess. As I recall it looks
sorta-like fiberglass. When you said " Should I be scared? " you got my
attention!!
Alan
Oct 31, 2019
303
I have one and it is a fine glass of some sort. I wouldn't be scared unless
you get really hungry and try to eat it. Alcohol is probably one of the
least dangerous fuels, but it doesn't heat as fast (it won't explode and
the fire can be put out with water -- well I guess it could be exploded,
but you'd have really try). Other cooking fuels are far more dangerous.
n4lbl
Oct 7, 2008
307
The first time I used the Origo I fueled it with the cylinders laying
horizontally. Fuel was everywhere but I didn't notice. I was almost to
the point of throwing the stove into the water when I got the flames out.
It was a little too much excitement. So,,, I agree: the Origo is safe *when
used correctly*!
Oct 30, 2019
1,459
I thnk it's glass wool.
Nicholas H. Walsh P.A.
120 Exchange Street
P.O. Box 7206
Portland ME 04112
207/772-2191
Fax 207/774-3940
This email is from a law firm and may contain material that is confidential
or privileged. If you suspect you were not the intended recipient, please
delete the email and give us a call.
Feb 12, 2008
337
It might be just plain wool. Wool doesn't burn easily. I found this out when buying oriental rugs, you can pull some fibers of a rug and try to light them. If they burn easily, the rug in not wool
(probably some synthetic). tg
________________________________
To: AlbinVega@yahoogroups.com
Sent: Wednesday, July 25, 2012 1:04 PM
Subject: Re: [AlbinVega] original non pressurized alcohol stove question...
attention!!
Alan
Feb 12, 2008
337
It is (some kind of) wool :" Simply pour denatured alcohol into Origo's
stainless-steel canister where fuel is absorbed and bound in a
non-flammable wool material "
I suppose if you are really worried about it, you could dry it out then put water on it to see if it smells like a wet sheep or wet fiberglass wool. tg
attention!!
Alan
