While it's true that being upright will make the foils more aerodynamically and hydrodynamically more efficient, the reality is the boat needs the rig to slightly overpower the resistive force of the keel to generate best speed. That creates heel. Depending on the boat, that's typically in the 10-12 degree range for most wind speeds.The more upright you can be the faster you go
