There's even more difference.
Optimas are probably the most expensive batteries on the market. The spiral-wound construction is supposed to make them more reliable, more uniform, and way cheaper to produce but they are sold at a very high premium price. And, putting round cells in a rectangular box means less capacity overall than a flat plate box.You can get conventional flat-plate AGM batteries for about 30% less from other sources.Trojan has a reputation for good industrial batteries, and wide distribution. They are among the most cost-effective batteries out there, although no one that I've heard of claims the 8-15 year life that some Rolls and Surrette buyers report. Those are top grade "industrial" brands for top dollar.AGM technology allows the battery to be charged at 25% of the rated capacity, i.e a 100-AH rated battery will take a charge at a 25A rate. A comparable wet cell would only accept a 20% rate before overheating and outgassing, so an AMG charges in 4 hours compared to 5 for a wet cell. In reality it won't be that simple--but it will still mean AGMs recharge about 25% faster than wet cells.AGM also self-discharges much slower, you can leave a charged AGM cell alone all winter and use it in the spring. A wet cell breaks down, sulphates form, and if it isnt' kept on a trickle charger or recharged every 30 days, it will suffer permanent capacity loss. Enough to kill it over six months of just sitting there.And then there's the acid. AGM means no spills, no cloths burned through. It also means that if you overcharge and cook them--you can't top them up, so your charger had better be working properly. Only one AGM maker recommends equalizing their own brand of AGM batteries (LifeLine), while every wet cell maker suggests equalizing be done from time to time. Bottom line? AGM will cost more, but it has some paybacks for that. Enough to pay maybe 30% more than wet lead? That's a personal decision. But please! Don't mistake "Optima" for "AGM" in general. That's like saying a Bentley and a Chevy are both cars. Yeah, they are, but they're not at all the same. (Bad analogy, the Bentley gives you way more than an Optima does for the money.<G>)
