forestay
the reason the Vision rig is unique is that other manufacturers who've produced boats with unstayed masts (Nonsuch, Freedom, Wyliecat) have opted to go with cat rigs, which make a ton of sense, especially with a wishbone boom. (Keep in mind that I race for Team Wyliecat, so this is hardly an unbiased opinion.)for whatever reason, Hunter came out with an sloop, opting to add a tiny jib on a forestay. Unfortunately, there's no good way to tension the forestay, which makes the jib fairly worthless. the other thing that's unique about the Vision is that the stick is made of aluminum rather than carbon fiber. the result is a huge circumference at the base of the mast, tapering to a tiny masthead. while it apparently performs almost as well as a carbon mast, it looks pretty goofy. not as goofy as a powerboat, however; I'm thinking you'll look a whole lot better sailing a Vision 36 than whatever it is you're driving now.
