So, when the distributor says the ACCO brand chain is hot dipped galvanized, it really isn't? I've observed the difference between electroplated (galvanized) versus hot dipped galvanized and the difference is stark. Our 1991 hot dipped galvanized Danforth anchor looks the same as when it was placed on our boat. Ditto the original chain. Then I've seen and used galvanized (electroplated) products that the sea water destroys in less than a season.
Not saying that your research was flawed, but perhaps worth a revisit. Certainly no expert in this field of metallurgy, only what I've observed in the real world. Others have chimed in on this topic more knowledgeable than I. Searching the archives will point out the differences between the two metal preps.
I've been using chain since the '60s and my opinion has nothing to do with "research". It is my observation, though. All the BBB chain I've used over the last dozen years has been somewhat shiny and the coating fairly even. As mentioned above, real hot dipped galvanized metal (chain, anchors, etc.) is dull and there is a lot of residual uneven zinc left on each bit. There was commonly a link or two with a hard connection to another where the zinc hardened and froze the junction. A time or two through the windlass and it would separate the links. I never see that in today's chain. It used to be one could have the chain dragging over the bottom for many years, but now one is unlikely to get a few years before it rusts, if used fairly often.
However, after many calls and emails to Acco and Canadian chain, they always assure me that what they are selling me is indeed "hot dipped". Either they don't know, or care, to tell me the truth, or somehow a new process for hot dipping chain is being used. I did hear that the reason there are so few companies offering real hot dipped regalvanizing in the US is because the process is extremely bad for he environment. One used to be able to re-hot dip galvanize metal very cheaply and everywhere. From what I hear one must go to Columbia (in this part of the world) to get metal (chain, anchors, etc.) properly hot dipped galvanized, but they apparently do not manufacture chain or anchors there.
