opening ports
Jul 22, 2010
8
Catalina 30 Kemah, Tx
I have a 1988 Catalina 30 and I am trying to replace the o rings on the opening ports but cannot find how to get the latch apart. There is no screw. Any ideas how to get the latch apart to install new o rings?
RonWG
Feb 15, 2015
6
Catalina C400 MkI West Basin St Joe MI
In center is a plug take a sharp object and work from all sides a little at a time it will pop out. Just did mine the old seals where cracked and brittle cleaned and coated new o-rings #41 with silicon grease not sure they are the right size still some leaks in rain. I have gaskets that's next.
Dec 2, 2010
76
Catalina 30mk cataumet Mass
Do you know where I can get Bomar Port Gaskets? Cat Direct has then for $35 each. To expensive but want isn't on a boat.
Thanks BobCat
