Norm, of course you can. We have Beckson ports in our cabin forward of the fixed portlights. Gray Marine ports are available right here on this website. All you need to do is
1 --- measure the dimensions of your existing fixed ports
2 --- review what is available from Gray or Beckson that will fit your opening. They should be slightly larger, not smaller, for obvious reasons.
You could also go the Lewmar route, but I wouldn't recommend it, 'cuz I read of so many Lewmar portlight leaks that it makes me gag, although they look nicer from outside the boat.
We have (8) 5 x 12 Becksons on our boat. I've only had to replace two of them, and it wasn't because the plastic was rotten in a 26 year old boat.
One had been messed with by the PO, the other one the dogs disintegrated and I found it easier to replace.
We have one Gray smaller one (4x10?) in the head. It leaks just a tad, but is most likely just in need of a new gasket, which I can cobble together from a hardware store bin.
I really like ours compared to other guys who have complained about their Lewmars.
Easy to open, come with screens.
Here are some photos: click on the links, too.
http://c34.org/bbs/index.php/topic,3241.0.html
