opening port window replacement knobs
H
harry
can anyone tell me where i could purchase replacement knobs for my port windows or would i have to replace the whole window? i am using a pair of pliers to tighten and loosen where the old knobs used to be. thanks
Dec 2, 1999
15,184
Bomar/Gray, WM, Sailnet, BoatUS...
Harry: They are available from any of the marine stores or the mfg. I think you can also use the ones for the Beckson units too. They run about $4-5 each. The new ones no longer have metal inserts, the are all plastic. I am assuming that you have Gray Ports.
C
chet p
right size
make sure that you check the thread size... I ordered the beckson quick latch fittings and they were 1/4-20 and the gray studs were 5/16-18...sent them back to BECKSON and they swaped them out ....list price of the beckson units are $9.50 for 3....nice things
