Open Ports O'Day 37
Régis
Mar 3, 2008
59
Oday 37 Peribonka
Can anyone tell me if the open ports are Beckson. If so what dimension model? 4"X10" or 5"X12". I have to change parts and I want good order. Thank Régis
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Régis
I have a 32 and the ports are Beckson,I measured the outside flange and figured out the model by cross reference with a Beckson catalog online and just last week I replaced one in the head and it fit perfectly. The one problem I did have was ODay did not caulk or seal the core between the inside and outside fiberglass so I had a sloopy mess in between that I needed to dry out and fill with new wood and epoxy and I hope when I do the aft cabin ports this fall I don't run into the same problem.
