Good purchase
David,Congrats on the 170 purchase! I own a gorgeous '99 model (with the original, lighter ---by all of 25 lbs.!!-- centerboard that's rued by some in the Forum Archives) and I'll tell ya, the 170s a great boat, and should serve you well. You've sailed Lasers so you know how to spill sail when puffs overwhelm. My early 170 is super-responsive to puffs and its main has to be reefed above 15knots to stay in control (singlehanding- no crew for added ballast). But I had chance to sail my cousin's 2003 170 in MN this summer and it IS more stable than the originals you might have been reading about. Go for it, man, you and your wife will love it. It's four times roomier than a Laser, stable so long as you reduce or spill sail in the big stuff and a blast to drop sails and swim off of. Hiking as in Laser can't be done effectively on the 170. Ironically its rounded gunwale shape and relative girth obviate attempts (at least by my usually singlehanded self) at bringing her down with a good hike. I actually rigged hiking straps on my 170 and they failed to remotely emulate the Laser hiking straps security, yet effectiveness. On my dad's Laser I can hike out so just my calves and feet are still in the boat-- not on the 170.One other note, when you're in steady stuff around 15mph or so, you'll notice that the jib overpowers the mainsail, swinging the boat off the wind and onto a reach or worse. I'm convinced Hunter/JY missed the sail area/sail foot placement correlations between jib and main (probably due to the high, tacking-friendly boom) when they designed the boat. The boat will be overpowered with leehelm if you fly too much jib in heavy air. Best to roller-reef in the jib in just slightly...reduce from it's full 55 sq ft to something like 35 or even 25 sq ft and the helm will balance out. To roller-reef effectively though, make sure that your rig is tuned drum-tight, otherwise the entire rig (shrouds, mast, boom) will shudder as big puffs hit. Heavy and potentially hazardous leehelm is the only quirk I've found in this excellent boat. One aside, the 170 bogs down on mainsail alone, and won't point high, so try to keep the jib in the game (if only reefed to 15 sq ft) as long as you can. BTW, the (slightly) "weighted centerboard, hull design and beam of the 170" hardly contribute to the 170s stability, as your dealer alleges... the boat is a higher performance daysailer, and needs proper sail handling and crew ballast to maintain stability (and speed). JY's smooth, Laser-like hull bottom and smooth (albeit wide) beam don't contribute much at all to the boat's stability. Most daysailers this size are actually more stable than the 170, but few are nearly as FUN. Have fun and just spill some sail when things get a little too spirited ;o) Full sails,Mike s/v Lil Sport
