Mark Johnson
Peggy: I spoke with you on the phone regarding y valves for the Vacuflush heads on my 460. You told me that vented loops must be installed between the y valve and the thru hull. My question is....the Vacuflush head only requires about 1 pint of water per flush. That doesn't seem like enough water to flush the waste from the pump up and over the loop and overboard. Am I right? All suggestions welcomed.MPJ
